Zum Hauptinhalt wechseln
Slingbox 500 Top Cover Replacement
Was du brauchst
  1. Slingbox 500 Top Cover Replacement, Top Cover: Schritt 1, Bild 1 von 1
    • Remove the sticker on the back of the Slingbox that covers the rear screws using a spudger.
  2. Slingbox 500 Top Cover Replacement: Schritt 2, Bild 1 von 2 Slingbox 500 Top Cover Replacement: Schritt 2, Bild 2 von 2
    • Remove the seven 7.9 mm rear screws from the device using a Phillips #1 screwdriver.
    • Flip your Slingbox so the bottom is facing upwards.
    • Remove the four 7.9 mm screws using a Phillips #1 screwdriver.
    • You may have rubber feet on the bottom of your Slingbox. If you do, just gently remove them with your hands and set them aside to put back on later.
  3. Slingbox 500 Top Cover Replacement: Schritt 3, Bild 1 von 3 Slingbox 500 Top Cover Replacement: Schritt 3, Bild 2 von 3 Slingbox 500 Top Cover Replacement: Schritt 3, Bild 3 von 3
    • Remove the upper section of the case by rotating your Slingbox to view the back and lifting up on the higher corner.
    • Use the opening tool to disconnect the small clips in the front.
    • These may require some minor force to disconnect.
    • Remove the entire top of the Slingbox and set it aside.
Abschluss
David Sullivan
365 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 1-3, Simcock Fall 2021 Mitglied von UMass Dartmouth, Team 1-3, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G3
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 64
