Zum Hauptinhalt wechseln
Einleitung
The purpose of this guide is to show the steps necessary to remove the casing of the Slingbox and replace the motherboard.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use the plastic opening tool to remove the four rubber pads from the bottom of the device.
    • Use the plastic opening tool to remove the four rubber pads from the bottom of the device.
  2. The Slingbox has four black 5mm screws, one on each corner of the case. Remove the four black 5mm screws using the PH1 screwdriver. Gently pull and separate the two case covers.
    • The Slingbox has four black 5mm screws, one on each corner of the case.
    • Remove the four black 5mm screws using the PH1 screwdriver.
    • Gently pull and separate the two case covers.
  3. The motherboard has five silver 5.5mm screws connecting it to the base of the Slingbox. Remove the five silver screws on the motherboard using the PH1 screwdriver. Gently slide and separate the motherboard from the base.
    • The motherboard has five silver 5.5mm screws connecting it to the base of the Slingbox.
    • Remove the five silver screws on the motherboard using the PH1 screwdriver.
    • Gently slide and separate the motherboard from the base.
Abschluss
IUPUI, Team 2-2, Harley SU 2016 Mitglied von IUPUI, Team 2-2, Harley SU 2016
IUPUI-HARLEY-SU16S2G2
5 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 462
