Einleitung
The purpose of this guide is to show the steps necessary to remove the casing of the Slingbox and replace the motherboard.
Was du brauchst
Use the plastic opening tool to remove the four rubber pads from the bottom of the device.
Remove the four black 5mm screws using the PH1 screwdriver.
Gently pull and separate the two case covers.
Remove the five silver screws on the motherboard using the PH1 screwdriver.
Gently slide and separate the motherboard from the base.
