Zum Hauptinhalt wechseln
SmartNav 4 false contact repair
Was du brauchst
  1. SmartNav 4 false contact repair, Device  dissasembly: Schritt 1, Bild 1 von 3 SmartNav 4 false contact repair, Device  dissasembly: Schritt 1, Bild 2 von 3 SmartNav 4 false contact repair, Device  dissasembly: Schritt 1, Bild 3 von 3
    • Gently open the four tabs with a small flathead screwdriver.
    • Carefully remove the black and silver cover.
  2. SmartNav 4 false contact repair: Schritt 2, Bild 1 von 2 SmartNav 4 false contact repair: Schritt 2, Bild 2 von 2
    • After detaching the two parts.
    • Unscrew the four hex screws with the 2mm hex key.
  3. SmartNav 4 false contact repair: Schritt 3, Bild 1 von 3 SmartNav 4 false contact repair: Schritt 3, Bild 2 von 3 SmartNav 4 false contact repair: Schritt 3, Bild 3 von 3
    • Remove and separate the components
    • The problem is caused by the black insulating film between the two boards which appears to be pierced through.
  4. SmartNav 4 false contact repair: Schritt 4, Bild 1 von 1
    • Remove the insulator, if present.
  5. SmartNav 4 false contact repair: Schritt 5, Bild 1 von 3 SmartNav 4 false contact repair: Schritt 5, Bild 2 von 3 SmartNav 4 false contact repair: Schritt 5, Bild 3 von 3
    • Prepare new divider. I used a 0.4mm rigid piece of plastic.
    • You can use a rigid piece of plastic, very thin (e.g. 0.4mm)
    • Take measurements and fit it.
  6. SmartNav 4 false contact repair: Schritt 6, Bild 1 von 3 SmartNav 4 false contact repair: Schritt 6, Bild 2 von 3 SmartNav 4 false contact repair: Schritt 6, Bild 3 von 3
    • Remake the device. Following the guide in reverse.
Abschluss
To re-assemble your device, follow the steps in reverse order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
it en
100%
Hier starten ›
Stefano Ficacci
166 Reputation
1 Anleitung geschrieben
2 Kommentare
Has anyone ever able to fix the issue with the smartnav not powering on
Shane Agnew - Antwort
I can give only the basic level of suggestions here.
The device is not responding at all, this is the situation I'm considering here, which means: no lights and no reaction from the computer when it is connected.
You should check first the cable and the computer port, this can be done with a different cable and a different port and/or with a different device on the same cable and port, better both methods.
Once you are sure that the cable and the port are good, you need to disassemble the unit, and you may need a tester for voltage and continuity.
A visual check will tell you if there are clear signs of problems such as cracks, rust or damaged components.
Chances are that the problem is in a faulty contact (the usb connector to begin with) but it still can be a defective component (the capacitors in this case).
From here on you may need to test the power supply to the ic circuit, without short circuiting other components with the probes.
A soldering unit could be necessary then.
Stefano Ficacci - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 9
Letzte 30 Tage: 13
Insgesamt: 1,265
