Einleitung
The charging port is the component of the phone that allows the charger to be connected to the phone in order to charge the internal rechargeable battery.
  1. Make sure the phone is turned off by pressing the power off button ensuring no data is lost.
    • Make sure the phone is turned off by pressing the power off button ensuring no data is lost.
    • Remove the back battery cover by sliding it downward and pushing simultaneously.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Using either your thumb or the opening tools, remove the battery by prying you in the direction of the arrow
    • Using either your thumb or the opening tools, remove the battery by prying you in the direction of the arrow
    • If removing battery is for the replacement of a new battery make sure to properly dispose of the old battery at a recycling center.
    • Remove the rubber inserts from the screw holes using the black metal tweezers. This is done by insering the tip of the metal tweezer down around the plastic insert.
    • Remove the 3.1mm long, Phillips #00 screws (Qty: 4) from the corners.
    • This is done by turning the skrew driver counter clockwise using little torque.
    • Seperate the phone's front case from the back case.
    • There is an intermediate decorative outlay around the front cases perimeter. This should be removed as well.
    • Remove volume slider button by using the tweezers to pry it out.
    • The volume slider button may fall out during the seperation of the front and back cases, this is ok.
    • Use the opening tools to seperate the circuit board from inside of the back case by prying between the circuit board and the case as shown.
    • The last picture is a view of the back of the circuit board.
    • Use tweezers to remove the charging port located inside the back cover of the phone.
    • A spudger may be needed to apply pressure with the use of the tweezers for easier removal.
Abschluss
Insert new charging port, and to reassemble your device, follow these instructions in reverse order.
John Bender
Mitglied seit 26.03.2014
822 Reputation
8 Anleitungen geschrieben
Clemson, Team 6-5, Benson Spring 2014 Mitglied von Clemson, Team 6-5, Benson Spring 2014
CLEM-BENSON-S14S6G5
3 Mitglieder
16 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 227
