Was du brauchst
The new shear bolt is stored on the top of the auger discharge
The shear bolt attaches the auger to the shaft
Locate the side with the missing shear bolt
Rotate the auger to find where the bolt is on the shaft
Use the new shear bolt to push the old broken bolt out of the shaft
It should fall out and look like this
Using two 7/16" wrenches tighten the nut on the bolt
Congratulations, both shear bolts have been replaced
2 weitere Nutzer:innen haben diese Anleitung absolviert.
