Zum Hauptinhalt wechseln
Snowboard Traction Pad Replacement
Was du brauchst
  1. Snowboard Traction Pad Replacement, Traction Pad: Schritt 1, Bild 1 von 2 Snowboard Traction Pad Replacement, Traction Pad: Schritt 1, Bild 2 von 2
    • Use a plastic or metal scraper to remove the existing traction pad.
  2. Snowboard Traction Pad Replacement: Schritt 2, Bild 1 von 3 Snowboard Traction Pad Replacement: Schritt 2, Bild 2 von 3 Snowboard Traction Pad Replacement: Schritt 2, Bild 3 von 3
    • If there is any residual adhesive left from the old traction pad, soak it with adhesive remover.
    • Let the adhesive remover sit for a few minutes.
    • Wipe away the residue using a towel and water.
    • Dry the the surface where the new traction pad will be placed.
  3. Snowboard Traction Pad Replacement: Schritt 3, Bild 1 von 3 Snowboard Traction Pad Replacement: Schritt 3, Bild 2 von 3 Snowboard Traction Pad Replacement: Schritt 3, Bild 3 von 3
    • Peel the back off of the new traction pad to reveal the adhesive.
    • When placed, the traction pad should be about an inch away from the rear binding.
    • To avoid creating air bubbles, start with one corner of the pad and roll the rest down.
    • Press down firmly to help it stick to the board and remove any air bubbles that may have occurred.
    • Give the adhesive a minimum of 12 hours to dry before use.
Ziellinie
Jacob Garcia
101 Reputation
1 Anleitung geschrieben
Cal Poly, Team 17-4, Forte Winter 2014 Mitglied von Cal Poly, Team 17-4, Forte Winter 2014
CPSU-FORTE-W14S17G4
5 Mitglieder
11 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 53
Insgesamt: 3,857
