Zum Hauptinhalt wechseln
Einleitung
This guide will instruct a person on how to replace the carbonation tube line used in the delivery of CO2.
  1. SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the front cover: Schritt 1, Bild 1 von 2 SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the front cover: Schritt 1, Bild 2 von 2
    • Locate the two prongs at the bottom of the button which releases the bottles (at the front of the machine).
    • Push both prongs down together; pull this part of the machine out towards you.
  2. SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the back cover: Schritt 2, Bild 1 von 2 SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the back cover: Schritt 2, Bild 2 von 2
    • Press in the two gray oval shaped buttons found on either side.
    • Gently pull back on the cover until it releases from the device.
    • Release the buttons and pull the back completely off.
  3. SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the Carbonation button: Schritt 3, Bild 1 von 2 SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the Carbonation button: Schritt 3, Bild 2 von 2
    • Place your hand under the carbonation button and pull up and away from you, towards the back of the machine.
    • Warning: be careful not to pull too hard on the carbonation button; there is a spring under this button that can become loose.
  4. SodaStream Fountain Jet A200 CO2 Tube Replacement, Tightening caps on tubes: Schritt 4, Bild 1 von 2 SodaStream Fountain Jet A200 CO2 Tube Replacement, Tightening caps on tubes: Schritt 4, Bild 2 von 2
    • Under the carbonation button, at the end of the slim black tube will be a white cap, turn the cap in a counter clock wise motion to remove.
    • Locate the second white cap, on the front of the machine. Reattach both white caps by turning them in a clockwise direction, ensuring they are on tight.
  5. SodaStream Fountain Jet A200 CO2 Tube Replacement, Putting machine back together: Schritt 5, Bild 1 von 1
    • Line up the prongs on the front cover with those on the machine and gently push until in place.
Abschluss
8 weitere Nutzer haben diese Anleitung absolviert.
7 Kommentare
Where do you find that black tube with the white caps on the internet. My white cap broke and can't find the replacement part.
Craig V - Antwort
mine broke too. plastic nut split in half. probably from chill of CO2 expansion.
where to get replacement part?
brockybeek - Antwort
I’m trying to find this nut and tube everywhere. any idea where we can purcase it? or the size and pitch of the nuts au tube?
Michel Bastien - Antwort
that makes four of us— where’s the tubing available??
jess youngquest - Antwort
Sodastream refuses to sell parts. Maybe get a non working one on eBay for parts.
jimmylasvegas - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 6
Letzten 7 Tage: 28
Letzten 30 Tage: 182
Insgesamt: 12,674
