Was du brauchst
Push the brass bar, located in the top of the device, out of the carbonating block.
Remove the plastic piece, located near the front of the carbonating block, from both sides of the device using a plastic opening tool or nylon spudger.
Pull the loader tab cover down and away from the rest of the carbonating block.
Unhook the four clips on the top of the carbonating block and remove the plastic cover.
Lift the clips located on both sides with the plastic spudger. Slide the front cover off.
Grip the right and left sides of the device and pull it into two identical halves.
Pull the foam pad up and remove it from the front side of the carbonation component.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Bonjour j'ai une pièce à l'intérieur dont je ne retrouve pas du tout la position au remontage.
Pouvez vous m'aider ?
De quelle partie s'agit-il, peux-tu prendre une photo ?
