Einleitung
The SodaStream Source is operated by a 3V lithium battery. If you are experiencing trouble with your device not turning on, or your LED lights are not coming on it could be that your battery needs to be replaced. This guide will instruct you on how to remove the carbonation block and replace the internal battery.
Was du brauchst
Remove the soda bottle and the CO₂ canister from the machine.
In diesem Schritt verwendetes Werkzeug:Phillips #1 Screwdriver$8.99
Remove the four 17.8 mm screws from the bottom metal base using a Phillips #1 screwdriver.
Remove the two 18.2 mm screws from the bottom of the front cover using a Phillips #1 screwdriver.
In diesem Schritt verwendetes Werkzeug:Jimmy$7.95
Firmly pull the front cover off.
24 weitere Nutzer:innen haben diese Anleitung absolviert.
20 Kommentare
Heel de achterkant hoeft er hiervoor niet af hoor juist de voorkant 2 vijsjes en je kan het voorste deksel er af klikken ;)
Perfectly explained! I was afraid to pull the front cover because it does indeed take a lot of force to pull off!!
its important to note it’s a C123A 3v battery, not the C2 3v as I found out after opening
Where is the best place to find these batteries? Canadian tire?
Its the same battery many many products use usually built in , motherboards used it for years.
Kal Jak -
Staples has the 123A 3v battery
