Was du brauchst
Remove the soda bottle and the CO₂ canister from the machine.
In diesem Schritt verwendetes Werkzeug:Phillips #1 Screwdriver$8.99
Remove the four 17.8 mm screws from the bottom metal base using a Phillips #1 screwdriver.
Remove the two 18.2 mm screws from the bottom of the front cover using a Phillips #1 screwdriver.
In diesem Schritt verwendetes Werkzeug:Jimmy$7.95
Firmly pull the front cover off.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
