Einleitung
Sometimes when you operate your SodaStream, the drink does not come out fizzy enough, or you can hear gas escaping on the inside. This may be an issue with the internal air hose. This is a small piece that is part of the inner machine setup. The hose is what helps the carbonation process, it connects the carbonation bottle with the nozzle on the main loader tab, and if it is damaged in any way you may not be able to use your device. In this guide, you will see how the hose can be disconnected and replaced if the need arises.
Ersatzteile
Keine Ersatzteile angegeben.
Remove the soda bottle and the CO2 canister from the machine.
Remove the four 17.8 mm screw from the bottom metal base using a Phillips #1 screwdriver.
Remove the two 18.2 mm screws from the bottom of the front cover using a Phillips #1 screwdriver.
Firmly pull the front cover off.
Push the gold bar, located in the top of the device, out of the carbonating block.
Remove the plastic piece, located near the front of the carbonating block, from both sides of the device using a plastic opening tool or nylon spudger.
Pull the loader tab cover down and away from the rest of the carbonating block.
Unhook the four clips on the top of the carbonating block and remove the plastic cover.
Lift the clips located on both sides with the plastic spudger. Slide the front cover off.
Grip the right and left sides of the device and pull it into two identical halves.
Pull the foam pad up and remove it from the front side of the carbonation component.
Use pliers to unscrew the gold cap piece from both ends of the tube
14 weitere Nutzer haben diese Anleitung absolviert.
48 Kommentare
Thanks for the guide, but i currently have this issue where the hose needs to be replaced, but no way of sourcing a spare part? Any clues anyone?
Did you ever find the part for your machine?
Where would you get this part
Exactly the same problem on my Source, but I can't find spare parts anywhere.
Has anyone found where to get them from in Australia?
did you ever find a supplier for the air hose replacement?
