Einleitung
The SodaStream Source carbonates water and adds flavor through its nozzle. This nozzle has a rubber seal to help prevent leakage and stabilize the carbonating block while making soda. If the seal is damaged, replacing it will stop leaking during your soda's creation. To replace this seal external and internal disassembly is required. This guide shows you how to access and remove a damaged seal.
Was du brauchst
Remove the soda bottle and the CO₂ canister from the machine.
In diesem Schritt verwendetes Werkzeug:Phillips #1 Screwdriver$8.99
Remove the four 17.8 mm screws from the bottom metal base using a Phillips #1 screwdriver.
Remove the two 18.2 mm screws from the bottom of the front cover using a Phillips #1 screwdriver.
In diesem Schritt verwendetes Werkzeug:Jimmy$7.95
Firmly pull the front cover off.
Push the brass bar, located in the top of the device, out of the carbonating block.
Remove the plastic piece, located near the front of the carbonating block, from both sides of the device using a plastic opening tool or nylon spudger.
Pull the loader tab cover down and away from the rest of the carbonating block.
Unhook the four clips on the top of the carbonating block and remove the plastic cover.
Lift the clips located on both sides with the plastic spudger. Slide the front cover off.
Grip the right and left sides of the device and pull it into two identical halves.
Pull the foam pad up and remove it from the front side of the carbonation component.
Remove the rubber seal from the nozzle piece and replace with the new seal.
29 weitere Nutzer:innen haben diese Anleitung absolviert.
50 Kommentare
I’ll ask the same question as the gentleman above. Where can I purchase the rubber gasket seal? I cannot find it anywhere online. I would also like to purchase the gas delivery tube and is installed.
Thank you
Peter (USA)
Our sodastream does not work anymore. It’s the electrick model with three different gasfillings. When you put the waterbottle into the filling station and then you turn your suitably filled bottle down and you try to push some of those lights (- /--/ ---) for to fill your bottle, it sounds like little choked “puff” and then all lights are blinking (I think they tell mailfunction). No gas comes. I have changed new and stuffed gasbottle, power cable is its place and works. So what’s wrong? Thank You allready, Juha Heikkilä (Finland).
I can’t remove the outer cover, step 3.
I am also looking for a gasket. Do you have any advice?
