Zum Hauptinhalt wechseln
Soft Touch Plastic Coating Removal
Was du brauchst
  1. Soft Touch Plastic Coating Removal, Clean With Isopropanol: Schritt 1, Bild 1 von 3 Soft Touch Plastic Coating Removal, Clean With Isopropanol: Schritt 1, Bild 2 von 3 Soft Touch Plastic Coating Removal, Clean With Isopropanol: Schritt 1, Bild 3 von 3
    • Generously apply alcohol directly to the goo.
    • Let it dissolve for a few seconds.
    • Scrub until clean.
Abschluss
Coat or vinyl wrap the shiny plastic to your liking. Some ideas include rubberized paint (plastidip) or flocking.
2 weitere Personen haben diese Anleitung absolviert.
Metals
133 Reputation
1 Anleitung geschrieben
Ein Kommentar
Isopropanol is commonly called isopropyl alcohol. It's found in pharmacies as "rubbing alcohol". Also sold in most hardware stores. Typically sold in strengths of 70% or 91%. The rest is water.
Isopropyl alcohol evaporates fairly quickly. The higher percentage of alcohol the faster the mixture will evaporate.
To deal with the evaporation, either work on a small area at a time, or wet the sticky part and wrap it in plastic wrap to allow the isopropyl alcohol to work for a time. Use a bit of paper towel to hold the alcohol where you want it.
You may want something to scrape off the goo rather than just trying to rub it off. iFixit has a soft plastic "iFixit Opening Tool" which will work, and may be safer for the underlying plastic than, say, a plastic paint scraper. The link has others options too, like the Spudger and Opening Picks.
https://www.ifixit.com/Tools/Prying_and_...
Get some "Goop" or other hand cleaner too. (Goop might also help remove the sticky paint. Haven't yet tried that.)
Winston - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 20
Letzte 7 Tage: 119
Letzte 30 Tage: 600
Insgesamt: 7,636
