Zum Hauptinhalt wechseln
Softball Glove String Replacement
Was du brauchst
  1. Softball Glove String Replacement, Softball Glove String: Schritt 1, Bild 1 von 3 Softball Glove String Replacement, Softball Glove String: Schritt 1, Bild 2 von 3 Softball Glove String Replacement, Softball Glove String: Schritt 1, Bild 3 von 3
    • Tie a knot at one end of the string.
  2. Softball Glove String Replacement: Schritt 2, Bild 1 von 2 Softball Glove String Replacement: Schritt 2, Bild 2 von 2
    • Put the string through the loop of the leather needle.
  3. Softball Glove String Replacement: Schritt 3, Bild 1 von 2 Softball Glove String Replacement: Schritt 3, Bild 2 von 2
    • Push the needle through the first hole on the backside of the pinky finger.
  4. Softball Glove String Replacement: Schritt 4, Bild 1 von 3 Softball Glove String Replacement: Schritt 4, Bild 2 von 3 Softball Glove String Replacement: Schritt 4, Bild 3 von 3
    • Pull the string out of the needle and back the needle out of the hole.
  5. Softball Glove String Replacement: Schritt 5, Bild 1 von 2 Softball Glove String Replacement: Schritt 5, Bild 2 von 2
    • Pull the string all the way through and reinsert the string into the needle.
  6. Softball Glove String Replacement: Schritt 6, Bild 1 von 2 Softball Glove String Replacement: Schritt 6, Bild 2 von 2
    • Push the needle through the bottom hole on the ring finger.
    • Pull the string out of the needle and all the way through the hole. Back the needle out of the hole.
  7. Softball Glove String Replacement: Schritt 7, Bild 1 von 3 Softball Glove String Replacement: Schritt 7, Bild 2 von 3 Softball Glove String Replacement: Schritt 7, Bild 3 von 3
    • Insert the string back into the needle and push it through the bottom hole on the pinky.
    • Pull the string all the way through and remove it from the needle.
  8. Softball Glove String Replacement: Schritt 8, Bild 1 von 3 Softball Glove String Replacement: Schritt 8, Bild 2 von 3 Softball Glove String Replacement: Schritt 8, Bild 3 von 3
    • Pull the string under the loop, making an X.
  9. Softball Glove String Replacement: Schritt 9, Bild 1 von 3 Softball Glove String Replacement: Schritt 9, Bild 2 von 3 Softball Glove String Replacement: Schritt 9, Bild 3 von 3
    • Put the string through the needle and push the needle though the top hole on the ring finger.
  10. Softball Glove String Replacement: Schritt 10, Bild 1 von 3 Softball Glove String Replacement: Schritt 10, Bild 2 von 3 Softball Glove String Replacement: Schritt 10, Bild 3 von 3
    • Going around the back of the ring finger, insert the string through the top hole on the left side of the ring finger.
    • Pull the string all the way through.
  11. Softball Glove String Replacement: Schritt 11, Bild 1 von 3 Softball Glove String Replacement: Schritt 11, Bild 2 von 3 Softball Glove String Replacement: Schritt 11, Bild 3 von 3
    • Insert the string through the bottom hole on the middle finger.
  12. Softball Glove String Replacement: Schritt 12, Bild 1 von 2 Softball Glove String Replacement: Schritt 12, Bild 2 von 2
    • Cross over the backside and insert the string into the bottom hole on the left side of the ring finger.
  13. Softball Glove String Replacement: Schritt 13, Bild 1 von 3 Softball Glove String Replacement: Schritt 13, Bild 2 von 3 Softball Glove String Replacement: Schritt 13, Bild 3 von 3
    • Pull the string under the loop to make an X.
  14. Softball Glove String Replacement: Schritt 14, Bild 1 von 3 Softball Glove String Replacement: Schritt 14, Bild 2 von 3 Softball Glove String Replacement: Schritt 14, Bild 3 von 3
    • Push the string through the top hole on the right side of the middle finger.
  15. Softball Glove String Replacement: Schritt 15, Bild 1 von 3 Softball Glove String Replacement: Schritt 15, Bild 2 von 3 Softball Glove String Replacement: Schritt 15, Bild 3 von 3
    • Going around the back of the middle finger, insert the string into top hole on the right side of the middle finger.
  16. Softball Glove String Replacement: Schritt 16, Bild 1 von 3 Softball Glove String Replacement: Schritt 16, Bild 2 von 3 Softball Glove String Replacement: Schritt 16, Bild 3 von 3
    • Insert the string into the bottom right hole on the pointer finger.
  17. Softball Glove String Replacement: Schritt 17, Bild 1 von 3 Softball Glove String Replacement: Schritt 17, Bild 2 von 3 Softball Glove String Replacement: Schritt 17, Bild 3 von 3
    • On the backside, push the string through the bottom left hole on the middle finger and pull the string all the way through.
  18. Softball Glove String Replacement: Schritt 18, Bild 1 von 3 Softball Glove String Replacement: Schritt 18, Bild 2 von 3 Softball Glove String Replacement: Schritt 18, Bild 3 von 3
  19. Softball Glove String Replacement: Schritt 19, Bild 1 von 3 Softball Glove String Replacement: Schritt 19, Bild 2 von 3 Softball Glove String Replacement: Schritt 19, Bild 3 von 3
    • Insert the string into the top right hole on the pointer finger and pull the string all the way through.
  20. Softball Glove String Replacement: Schritt 20, Bild 1 von 3 Softball Glove String Replacement: Schritt 20, Bild 2 von 3 Softball Glove String Replacement: Schritt 20, Bild 3 von 3
    • Tie the end of the string close to the glove.
    • Cut off the excess string.
Abschluss
To remove a string from a softball glove, repeat these steps in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
Christina Hart
331 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S1-G3, Gulbrandsen Spring 2021 Mitglied von UMass Dartmouth, Team S1-G3, Gulbrandsen Spring 2021
UMASSD-GULBRANDSEN-S21S1G3
1 Mitglied
2 Anleitungen geschrieben
1 Kommentar zur Anleitung
Thank you so much for sharing this guide on softball glove string replacement! Your step-by-step instructions made it easy for me to replace the strings on my old glove and bring it back to life. Your expertise and generosity are truly appreciated!
Juliet Cyrus - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 30
Insgesamt: 1,061
