Einleitung
This guide will teach you how to replace the speakers for the Sol Republic Deck.
Was du brauchst
With plastic spudger wedge in between the top and bottom casings to force sepearation . Exposing the inside components of the Republic Deck.
Use the screwdriver to unscrew 2 3.63mm Phillips #0 screws securing the plastic plate.
Unscrew 15 6.15 mm Phillips #0 screws and lift the black plastic plate from the case.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
