Zum Hauptinhalt wechseln
Solio CLASSIC2 Disconnecting the Battery
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Solio CLASSIC2 Disconnecting the Battery, Disconnecting the Battery: Schritt 1, Bild 1 von 1
    • Turn off the device by pressing on the clear power button behind the device.
    • To make sure that it is off, make sure the button is not flashing green.
  2. Solio CLASSIC2 Disconnecting the Battery: Schritt 2, Bild 1 von 1
    • Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
  3. Solio CLASSIC2 Disconnecting the Battery: Schritt 3, Bild 1 von 3 Solio CLASSIC2 Disconnecting the Battery: Schritt 3, Bild 2 von 3 Solio CLASSIC2 Disconnecting the Battery: Schritt 3, Bild 3 von 3
    • Using the plastic opening tools, gently pry open the side of the large panel.
    • Keeping the tool in, slowly slide the tool along the side of the panel.
  4. Solio CLASSIC2 Disconnecting the Battery: Schritt 4, Bild 1 von 2 Solio CLASSIC2 Disconnecting the Battery: Schritt 4, Bild 2 von 2
    • Rotate the device 180 degrees.
    • Make sure the opening on other side of the device does not snap closed.
    • Gently slide the plastic opening tool along the side of the panel.
  5. Solio CLASSIC2 Disconnecting the Battery: Schritt 5, Bild 1 von 2 Solio CLASSIC2 Disconnecting the Battery: Schritt 5, Bild 2 von 2
    • Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel.
    • Using both hands, slowly pull apart the back panel from the rest of the device.
    • Gently flip the back panel open so the circuit board faces up and the two panels are side by side.
  6. Solio CLASSIC2 Disconnecting the Battery: Schritt 6, Bild 1 von 2 Solio CLASSIC2 Disconnecting the Battery: Schritt 6, Bild 2 von 2
    • Softly pinch the red and blue wires close to the white connector.
    • To pull the wires out, wiggle them back and forth until the connector is fully out.
Abschluss
Johnny Tran
311 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 4-28, Amido Fall 2013 Mitglied von Cal Poly, Team 4-28, Amido Fall 2013
CPSU-AMIDO-F13S4G28
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 86
