Einleitung
A batteries' cycle life will only last for so many charges. In time the battery may no longer hold a charge to power your device. In this guide, we will show you how to change the battery of the Solio Rocsta.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
    • Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
  2. Remove top cover.
    • Remove top cover.
    • Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire .
    • Using the spudger, pry the battery off the back cover.
    • Using a T6 Torx screwdriver, unscrew the 5.66 mm screws attaching the circuit board to the case and flip the circuit board.
    • With the circuit board flipped, locate the battery connector.
    • Hold the component attached to the circuit board the battery is connected to and wiggle the cable out.
Abschluss
David Vazquez
Mitglied seit 10.10.2017
529 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S13-G13, Cagle Fall 2017 Mitglied von USF Tampa, Team S13-G13, Cagle Fall 2017
USFT-CAGLE-F17S13G13
4 Mitglieder
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 41
