Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
A rugged outdoor lifestyle may sometimes cause the cover, of your Solio Rocsta, to get dirty and/or damaged. In this guide, we will show you how to remove the top cover of the Solio Rocsta and replace it.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver. Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
    • Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
  2. Manta Precision Bit Set
    112 bits for every fix.
    Upgrade Your Toolbox
  3. Remove top cover. Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire .
    • Remove top cover.
    • Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire .
  4. Using the spudger, pry the solar panel off the cover.
    • Using the spudger, pry the solar panel off the cover.
Abschluss
Denis Laesker
107 Reputation
1 Anleitung geschrieben
USF Tampa, Team S13-G13, Cagle Fall 2017 Mitglied von USF Tampa, Team S13-G13, Cagle Fall 2017
USFT-CAGLE-F17S13G13
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 30
