Zum Hauptinhalt wechseln
Solved: Netgear Address Reservation - Invalid MAC Address [Workaround]
  1. Solved: Netgear Address Reservation - Invalid MAC Address [Workaround], Press F12 to enter browser inspector: Schritt 1, Bild 1 von 1
    • Select Network tab to see URLs accessed
  2. Solved: Netgear Address Reservation - Invalid MAC Address [Workaround], Click Add to reserve IP address: Schritt 2, Bild 1 von 1
    • Get Invalid MAC address error
    • This populates the Network tab with a list of URLs accessed
  3. Solved: Netgear Address Reservation - Invalid MAC Address [Workaround], Right-click reserv.cgi? to bring up context menu: Schritt 3, Bild 1 von 1
    • This is the POST that sends your request to the back end
    • Select Edit and Resend
    • [Chrome only] Menu doesn't have this option so select Copy as fetch instead.
  4. Solved: Netgear Address Reservation - Invalid MAC Address [Workaround], Edit POST Body to add colons to MAC address: Schritt 4, Bild 1 von 1
    • Click Send to POST request to back end
    • [Chrome only] Paste command to console and edit command line to add colons. Press Enter to send POST from console.
    • NB: Screen doesn't change when you press Send. But you don't get the error.
    • Click LAN Setup to go to previous screen to see new reservation at the bottom of the page.
Ziellinie
7 weitere Personen haben diese Anleitung absolviert.
Alan Nishioka
3.507 Reputation
8 Anleitungen geschrieben
11 Kommentare
i hit send but nothing happened. dont see the address listed in the LAN setup. What am i missin?
marvin kravets - Antwort
Did you get any error?
Did you reload LAN setup? I don't see any change to the screen when I press send, but clicking LAN Setup shows the new reservation at the bottom of the page.
Alan Nishioka -
No i dont see any errors. I hit send it does a quick loading of something within the network console and nothing else happens. I refresh page and no change.
looks like i had to do something else than your instructions.. after I edit and send it and i found the entry in the network log file I right click again and selected open in new tab and it seemed to work that way. Thanks.
This worked for me! thanks so much!
Alec Tardy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 20
Letzte 30 Tage: 83
Insgesamt: 2,379
