Zum Hauptinhalt wechseln
Einleitung
There are two boards for the device, a green top level and a blue lower level. This guide will show the steps to replace the top motherboard.
  1. Start by using a spudger or plastic opening tool  to  remove the bottom cover. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible. Once enough of the glue is removed, peel the cover off by hand,
    • Start by using a spudger or plastic opening tool to remove the bottom cover.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Once enough of the glue is removed, peel the cover off by hand,
  2. Remove the four 7.5mm length Philips head screws under the rubber cover. Remove the four 7.5mm length Philips head screws under the rubber cover. Remove the four 7.5mm length Philips head screws under the rubber cover.
    • Remove the four 7.5mm length Philips head screws under the rubber cover.
  3. Use a nylon spudger to unsnap the bottom from the sides. Pry until the remaining three points are unsnapped. Once unsnapped, lift the cover.
    • Use a nylon spudger to unsnap the bottom from the sides.
    • Pry until the remaining three points are unsnapped.
    • Once unsnapped, lift the cover.
  4. Remove the connection for the front buttons to fully remove the cover. Remove the connection for the front buttons to fully remove the cover.
    • Remove the connection for the front buttons to fully remove the cover.
  5. Use a plastic opening tool or spudger to remove the adhesive covering the the WIFI connectors. Gently pull the wires at the connection point to disconnect them from the motherboard.
    • Use a plastic opening tool or spudger to remove the adhesive covering the the WIFI connectors.
    • Gently pull the wires at the connection point to disconnect them from the motherboard.
  6. Remove the two pieces of glue holding the WIFI card in place. Remove the two pieces of glue holding the WIFI card in place.
    • Remove the two pieces of glue holding the WIFI card in place.
  7. Scrape the glued pad underneath the WIFI card to seperate the card from the board. Push apart the two clips holding the WIFI card in the connection. Pull the WIFI card out of the connection.
    • Scrape the glued pad underneath the WIFI card to seperate the card from the board.
    • Push apart the two clips holding the WIFI card in the connection.
    • Pull the WIFI card out of the connection.
    • When putting the new WIFI card in, put the card in the connector first, then push downward until it clicks.
  8. Remove the 7mm length Phillips screw holding the board in place.
    • Remove the 7mm length Phillips screw holding the board in place.
  9. Flip the board over to access the Molex Cable. Flip the board over to access the Molex Cable.
    • Flip the board over to access the Molex Cable.
  10. Disconnect the Molex Cable from the top motherboard.
    • Disconnect the Molex Cable from the top motherboard.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Clark Snyder
454 Reputation
4 Anleitungen geschrieben
IUPUI, Team 3-2, Baechle Spring 2016 Mitglied von IUPUI, Team 3-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G2
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 5
Letzten 30 Tage: 19
Insgesamt: 1,473
