Was du brauchst
Remove the four T20 screws securing the driver to the front panel.
The insulated terminal simply disconnects
Remove the midwoofer from the unit
Lift the midwoofer out of the cabinet slightly to disconnect the terminals
The insulated terminal simply slides off, but the non insulated terminal has a locking tab that must be depressed.
Lift the driver out of the cabinet.
The left noninsulated terminal has a locking tab that must be depressed. The right terminal simply pulls off
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
Hola sabes donde podría comprar los parlantes tengo un somos five y están las tres bocinas reventadas
Ricardo.tranamil.h@gmail.com
Hola nesecito comprar las bocinas de repuestos por favor
