Einleitung
This guide is for the replacement of the control panel and microphones for the Sonos One.
  1. Disconnect all power cords.
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
  2. Remove the four 10mm Torx T10 screws from the bottom of the speaker.
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
    • Slide the protective cover upwards to remove.
    • Use the pointed end of a spudger to remove the covers that hide the screws.
    • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
    • With the front of the unit facing you, lift the control panel up using your thumbs.
    • There's a ribbon cable attaching the control panel to the speaker so work slowly.
    • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
    • Pull the control panel ribbon cable out of its socket.
    • Pull the control panel away from the speaker to separate.
Abschluss
Marcus Glowa
Mitglied seit 14.02.2018
653 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S2-G1, Nance Spring 2018 Mitglied von USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 18
Letzte 30 Tage: 116
Insgesamt: 655
