Einleitung
Prerequisite Only
Was du brauchst
Unscrew eight 1.5 inch Phillips #2 screws attaching the front speaker panel to the box.
Unscrew the single 1 inch Phillips #2 screw located on the left side of the panel. This may be hidden beneath the warranty void sticker that you'll want to remove.
Unscrew the single 3/4 inch Phillips #2 screw, which is the last thing holding the front panel to the casing.
Disconnect the front panel from the motherboard by gently reaching in and pushing the tab underneath the wire connector and pulling towards you.
Gently remove the wireless card located at the bottom of the front speaker panel by pulling up and out with your index finger and thumb.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
