Einleitung
Replacing all antennas on Sonos Play 5
Was du brauchst
Disconnect any power to the speaker and wait a few minutes for the capacitors to fully discharge.
Flip the speaker upside down.
Remove eight 10mm Phillips #2 screws
Remove the bottom panel by pulling upwards.
Flip the device so that the grille is facing up.
Locate the line on the right side of the speaker where the grill and the plastic meet, and place your plastic opening tool in the gap.
Run the spudger along the gap, loosening the grille from the plastic. Repeat this process on the left side as well.
Gently pull up on the grille, removing it from the front panel.
Locate the line on the right side where the front panel and back panel meet. Place a plastic opening tool in the gap, and run it along the gap. Repeat this on the left side.
Use the opening tool to lift the front plate. If a plastic tool is not providing enough leverage, use a metal opening tool.
Gently pull up on the face plate to ensure it has been detached from the enclosure.
Lift up the front panel, forming a 90 degree angle with the back panel. Locate the locate ten pin connector shown. This is the wire that connects the front panel to back panel.
Press down on the small tab located on the connector. With the tab firmly pressed down, pull the connector out from its socket.
The faceplate assembly is now fully detached from the rest of the speaker.
Remove the grey and red antenna connectors by lifting them away from the board.
Pull cords away from the board.
Remove the yellow antenna connector by lifting it away from the board.
Pull cord away from the board.
Flip device so that the bottom is facing upwards.
Identify the 3 antennas to be replaced.
Remove first rubber strain relief by pinching the rubber then lifting up and away.
Remove second rubber strain relief by pinching the rubber then lifting up and away.
Remove third rubber strain relief by pinching the rubber then lifting up and away.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
