Zum Hauptinhalt wechseln
Sonos Play 5 Bass Speaker Replacement
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. Sonos Play 5 Bass Speaker Replacement, Sonos Play 5 Disassembly: Schritt 1, Bild 1 von 3 Sonos Play 5 Bass Speaker Replacement, Sonos Play 5 Disassembly: Schritt 1, Bild 2 von 3 Sonos Play 5 Bass Speaker Replacement, Sonos Play 5 Disassembly: Schritt 1, Bild 3 von 3
    • Use the metal spudger to pry open the front grill. Little force will be needed to wedge the metal spudger into the crevice.
    • After the grill has been loosened on all edges. Use your fingers as a wedge and gently pull the grill off the speaker. This will reveal the front speaker panel.
  2. Sonos Play 5 Bass Speaker Replacement: Schritt 2, Bild 1 von 3 Sonos Play 5 Bass Speaker Replacement: Schritt 2, Bild 2 von 3 Sonos Play 5 Bass Speaker Replacement: Schritt 2, Bild 3 von 3
    • Use a pointed metal spudger to remove the rubber plugs covering the screws in the bottom left and right corners of the speaker panel.
    • Insert the spudger against the side of the rubber plug and the speaker panel while leveraging upward.
    • Remove the eight 12 mm Phillips #1 screws bordering the front speaker panel.
  3. Sonos Play 5 Bass Speaker Replacement: Schritt 3, Bild 1 von 2 Sonos Play 5 Bass Speaker Replacement: Schritt 3, Bild 2 von 2
    • Orient the speaker so that the volume and speaker control buttons are facing down onto your work space. The Sonos name and product number should be facing upward toward the ceiling
    • Use a metal spudger to pry the outer corner of the grey rubber pad revealing eight 12mm screws.
  4. Sonos Play 5 Bass Speaker Replacement: Schritt 4, Bild 1 von 3 Sonos Play 5 Bass Speaker Replacement: Schritt 4, Bild 2 von 3 Sonos Play 5 Bass Speaker Replacement: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • With a #1 Phillips-head screwdriver, remove the eight 12mm screws on the bottom panel.
    • We have marked the original placement of the warranty stickers in orange. To remove use a pair of tweezers to grip onto the sticker and pull with a gentle upward motion
    • We have already removed the warranty stickers in this picture.
  5. Sonos Play 5 Bass Speaker Replacement: Schritt 5, Bild 1 von 1
    • Orient the speaker so that the speaker panel is facing upward.
    • With a metal spudger, apply medium force and wedge the spudger into the crevice with a prying motion
    • This action will need to be repeated on all sides to allow for the panel to be opened up
  6. Sonos Play 5 Bass Speaker Replacement: Schritt 6, Bild 1 von 3 Sonos Play 5 Bass Speaker Replacement: Schritt 6, Bild 2 von 3 Sonos Play 5 Bass Speaker Replacement: Schritt 6, Bild 3 von 3
    • Use both hands to lift the front speaker panel away from the skeleton of the speaker housing.
    • While removing the front speaker panel, pay close attention to the bottom right-hand corner. There will be an antenna connector you will need to remove in the next step.
  7. Sonos Play 5 Bass Speaker Replacement: Schritt 7, Bild 1 von 2 Sonos Play 5 Bass Speaker Replacement: Schritt 7, Bild 2 von 2
    • Using your thumb and forefinger to grip the antenna clasp while moving outward and away from the motherboard.
    • Do not use excessive force while disconnecting. This will damage the connector and motherboard.
    • We have removed the bottom panel in this picture for another guide.
  8. Sonos Play 5 Bass Speaker Replacement, Sonos Play 5 Bass Speaker: Schritt 8, Bild 1 von 2 Sonos Play 5 Bass Speaker Replacement, Sonos Play 5 Bass Speaker: Schritt 8, Bild 2 von 2
    • The bass is located in the middle of the two mid-range driver speakers
    • Point of reference: This picture illustrates the back-side of the speaker panel.
  9. Sonos Play 5 Bass Speaker Replacement: Schritt 9, Bild 1 von 2 Sonos Play 5 Bass Speaker Replacement: Schritt 9, Bild 2 von 2
    • Use a Philips screwdriver bit-size #1 to remove the four 10mm screws surrounding the bass.
  10. Sonos Play 5 Bass Speaker Replacement: Schritt 10, Bild 1 von 2 Sonos Play 5 Bass Speaker Replacement: Schritt 10, Bild 2 von 2
    • Disconnect the two spade connectors from the tabs on the speaker.
  11. Sonos Play 5 Bass Speaker Replacement: Schritt 11, Bild 1 von 2 Sonos Play 5 Bass Speaker Replacement: Schritt 11, Bild 2 von 2
    • Remove the bass speaker from its seat by grasping the back-end and pulling upward.
Abschluss
Minh Bui
101 Reputation
1 Anleitung geschrieben
CSU Fullerton, Team 2-1, Bruce Fall 2015 Mitglied von CSU Fullerton, Team 2-1, Bruce Fall 2015
CSUF-BRUCE-F15S2G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 551
