Was du brauchst
Use the metal spudger to pry open the front grill. Little force will be needed to wedge the metal spudger into the crevice.
After the grill has been loosened on all edges. Use your fingers as a wedge and gently pull the grill off the speaker. This will reveal the front speaker panel.
Use a pointed metal spudger to remove the rubber plugs covering the screws in the bottom left and right corners of the speaker panel.
Insert the spudger against the side of the rubber plug and the speaker panel while leveraging upward.
Remove the eight 12 mm Phillips #1 screws bordering the front speaker panel.
Orient the speaker so that the volume and speaker control buttons are facing down onto your work space. The Sonos name and product number should be facing upward toward the ceiling
Use a metal spudger to pry the outer corner of the grey rubber pad revealing eight 12mm screws.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
With a #1 Phillips-head screwdriver, remove the eight 12mm screws on the bottom panel.
We have marked the original placement of the warranty stickers in orange. To remove use a pair of tweezers to grip onto the sticker and pull with a gentle upward motion
Orient the speaker so that the speaker panel is facing upward.
With a metal spudger, apply medium force and wedge the spudger into the crevice with a prying motion
Use both hands to lift the front speaker panel away from the skeleton of the speaker housing.
Using your thumb and forefinger to grip the antenna clasp while moving outward and away from the motherboard.
Face the speaker with the power port facing you.
Use a metal spudger with a pointed tip to help remove the grey sticker from the back panel.
Use a #1 Philips-head screwdriver to remove two 10mm screws that surround the power and AC ports.
Use a #00 Phillips-head screwdriver to remove the remaining six 5 mm screws around the two jacks located on the lower half of the panel.
Remove the cable connected to the amplifier by gently pulling the cable away from the amplifier.
The cable wiring is now disconnected from the amplifier.
Turn the speaker upside down, with the volume buttons facing down.
Use a #1 Phillips-head screwdriver to remove the six 10 mm screws at the bottom of the speaker.
Gently lay the speaker flat, with the interior of the speaker facing the surface.
Slide out the amplifier and motherboard as one unit.
Use a 6 mm Allen socket to remove the four bolts attaching the amplifier to the motherboard.
Slowly lift the amplifier away from the motherboard.
