Einleitung
This guide shows how to replace the Ethernet Port from the Sonos Playbase, which connects the Playbase to the internet.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Pro Tech Toolkit$59.96
Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
Unplug the Ethernet Port from the main circuit board by pinching the white clip and pulling upward.
Remove the Ethernet Port from the housing by pinching from both sides and pulling it out.
Ein Kommentar
I actually have a broken ethernet port on a playbase. Do you have any idea where I can buy a replacement port?
Thanks,
D
