Zum Hauptinhalt wechseln
Sonos Playbase Optical Audio Port Replacement
Was du brauchst
  1. Sonos Playbase Optical Audio Port Replacement, Bottom Panel: Schritt 1, Bild 1 von 3 Sonos Playbase Optical Audio Port Replacement, Bottom Panel: Schritt 1, Bild 2 von 3 Sonos Playbase Optical Audio Port Replacement, Bottom Panel: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Pro Tech Toolkit
    $74.95
    Kaufen
    • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
    • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
    • Melt the adhesive with an iOpener for ease of opening
    • Use a Metal Spudger if the plastic spudgers do not work.
    • Take care to avoid damaging the plastic or the device if using a metal spudger.
  2. Sonos Playbase Optical Audio Port Replacement: Schritt 2, Bild 1 von 2 Sonos Playbase Optical Audio Port Replacement: Schritt 2, Bild 2 von 2
    Pro Tech Toolkit
    $74.95
    Kaufen
    • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
    • Remove the seven 44mm T-20 screws by turning counter-clockwise.
    • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
    • Record where each screw belongs for easier reassembly.
  3. Sonos Playbase Optical Audio Port Replacement: Schritt 3, Bild 1 von 2 Sonos Playbase Optical Audio Port Replacement: Schritt 3, Bild 2 von 2
    Pro Tech Toolkit
    $74.95
    Kaufen
    • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
    • Use a metal spudger if plastic openers do not work.
  4. Sonos Playbase Optical Audio Port Replacement, Optical Audio Port: Schritt 4, Bild 1 von 2 Sonos Playbase Optical Audio Port Replacement, Optical Audio Port: Schritt 4, Bild 2 von 2
    • Unplug the optical audio port from the main circuit board by pinching the white clip and pulling upward.
  5. Sonos Playbase Optical Audio Port Replacement: Schritt 5, Bild 1 von 2 Sonos Playbase Optical Audio Port Replacement: Schritt 5, Bild 2 von 2
    • Remove the three 38mm T-55 screws preventing you from removing the Optical Audio Port screws by turning them counterclockwise.
  6. Sonos Playbase Optical Audio Port Replacement: Schritt 6, Bild 1 von 2 Sonos Playbase Optical Audio Port Replacement: Schritt 6, Bild 2 von 2
    Pro Tech Toolkit
    $74.95
    Kaufen
    • Remove the two 18mm T-10 screws holding the Ethernet Port in place by turning them counterclockwise.
  7. Sonos Playbase Optical Audio Port Replacement: Schritt 7, Bild 1 von 2 Sonos Playbase Optical Audio Port Replacement: Schritt 7, Bild 2 von 2
    • Remove the Optical Audio Port from the housing by pinching the sides and pulling outward.
Abschluss
James Andrews
421 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S17-G2, White Fall 2018 Mitglied von Cal Poly, Team S17-G2, White Fall 2018
CPSU-WHITE-F18S17G2
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Thank you for this guide, but any idea where to purchase a replacement optical audio port from?
donovanclarkson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 24
Insgesamt: 2,328
