Einleitung
In order to interface with the camera and access its functions, it is important to have a working LCD screen. If your LCD screen has problems such as distortion and flickering, it may be damaged and in need of replacement. This guide will walk you through disassembling the camera and removing the LCD screen; avoid tearing the flat ribbon cables exposed in the process. When removing the screen from the plastic frame, you will break the adhesive attaching it. If desired, you may reglue the replacement screen to the frame with any super glue or epoxy. This guide requires JIS 00 and 000 screwdrivers, opening tools, a spudger, and tweezers.
Was du brauchst
Flip the camera upside down.
Slide the battery compartment lock to OPEN to unlock it.
Flip the LCD screen down to access the back side.
Remove two 2mm JIS 000 screws to release the back panel of the screen.
Use the opening tool to pry open the back panel.
Remove the black plastic spacer laying on top of the circuit board.
Slide the spudger around all sides of the screen's plastic frame, gently breaking the adhesive.
Remove the screen from the camera by prying it out.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Hello, do you have an updated link with a currently available lcd screen replacement part?
Can I use an a6500 screen to replace an a6600 screen? Are they interchangeable?
