Einleitung
If the top of your camera is damaged or broken, this guide will walk you through its replacement. The removal of the top of the camera is also a prerequisite for the replacement of the flash unit, memory card reader, motherboard, viewfinder glass, and other complex components. You will require a JIS 0 screwdriver, JIS 00 screwdriver, JIS 000 screwdriver, tweezers, and opening tools.
Was du brauchst
Flip the camera upside down.
Slide the battery compartment lock to OPEN to unlock it.
Press the flash popup button on the back of the camera.
Remove one 5 mm JIS 00 screw from inside the flash compartment.
Remove one 4 mm JIS 00 screw.
Remove the 2.5 mm JIS 00 screw from the side of the camera near the viewfinder.
Use the opening tool to pry off the small cover.
Remove two 2.5 mm JIS 00 screws from underneath the cover.
Remove a 5 mm JIS 00 screw from underneath the cover.
Remove three 2.5 mm JIS 0 screws from the back face of the camera.
Remove one 4 mm JIS 00 screw from the underside of the lip that overhangs the back of the camera.
Flip the battery lock switch to open and open the battery compartment.
Remove three 2.5 mm JIS 00 screws from the top of the battery compartment.
Use the plastic opening tool to begin prying off the back of the camera from the side.
Continue to loosen the back until you can open it from the bottom.
Open the back of the camera.
Use tweezers to remove two ribbon connectors from underneath the back. One connects to the LCD display and the other connects to the right side behind the battery compartment.
Use the plastic opening tool to peel down the rubber grip around the handle at least 1 cm.
Remove one 3 mm JIS 000 screw from underneath the rubber grip on the right side.
Remove one 4 mm JIS 000 screw from the left side.
Insert a long, thin JIS 00 screwdriver through the two holes and into the battery compartment; remove the two 5mm JIS 00 screws inside it.
Use the long, thin, screwdriver to remove one 5 mm JIS 00 screw inside the camera accessible below the dials from the back.
Use the plastic opening tool to gently lift up the shutter button assembly.
Grasp the front grip from the top and bottom and pull it off. It should come off easily with the shutter button out of the way.
Remove one 2.5 mm JIS 00 screw from where the shutter button assembly used to be.
Remove one 3 mm JIS 00 screw from the side of the camera.
Carefully unplug the two ribbon connectors attaching the top assembly to the rest of the camera.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
