Einleitung
This guide will provide you with a detailed process on how to replace the back case of a Sony a6000 camera. Prior to replacing the case, make sure to remove the battery. Steps 1-4 will guide you on how to take out the battery and steps 5-12 guide you on how to replace the back case. The recommended tools for this procedure are a screwdriver, opening tools, a magnetic project mat, and gloves.
Was du brauchst
Position the camera with the bottom facing upwards and the lens facing away from you.
Slide the notched locking bar on the battery compartment from LOCK to OPEN.
Once the battery is removed, use a Phillips #00 screwdriver to remove the three screws at the bottom of the battery compartment.
Use the Phillips #00 screwdriver to remove the screws located next to the camera strap.
Position the camera with the battery housing facing upwards.
Remove the two screws on the bottom of the camera using the Phillips #00 screwdriver.
Position the camera with the flash assembly facing upwards.
Remove the screw located underneath with a Phillips #00 screwdriver.
Pull back the LCD screen.
Remove the three screws directly underneath using the Phillips #00 screwdriver.
Gently pop off the top case of the camera using your fingers or a plastic opening tool.
Position the camera with the LCD screen facing upwards.
Gently remove the back case guiding it around the LCD screen.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
