Zum Hauptinhalt wechseln
Sony AZ1VR LCD Side Display Replacement
Was du brauchst
  1. Sony AZ1VR LCD Side Display Replacement, LCD Side Display: Schritt 1, Bild 1 von 3 Sony AZ1VR LCD Side Display Replacement, LCD Side Display: Schritt 1, Bild 2 von 3 Sony AZ1VR LCD Side Display Replacement, LCD Side Display: Schritt 1, Bild 3 von 3
    • Remove the two screws on the bottom of the camera.
    • Remove the screw inside the battery door.
    • Once these are removed, slide the door out, and the small piece of plastic with the door.
  2. Sony AZ1VR LCD Side Display Replacement: Schritt 2, Bild 1 von 3 Sony AZ1VR LCD Side Display Replacement: Schritt 2, Bild 2 von 3 Sony AZ1VR LCD Side Display Replacement: Schritt 2, Bild 3 von 3
    • Grab the lens and pull the body out of the plastic, this will reveal the insides of the device.
    • You'll see a screw on the top of the device, towards the front, remove this screw.
    • Pull the tabs on the bottom and top of the lens, and pull outward, this will remove the lens housing from the body.
  3. Sony AZ1VR LCD Side Display Replacement: Schritt 3, Bild 1 von 3 Sony AZ1VR LCD Side Display Replacement: Schritt 3, Bild 2 von 3 Sony AZ1VR LCD Side Display Replacement: Schritt 3, Bild 3 von 3
    • Remove the screws connected to the silver metal plate.
    • Remove the plate by pulling the back up and pushing it towards the front.
    • Remove the screw directly above the LCD display.
    • Pull the plastic up gently, it will be connected by cables on the bottom.
    • Disconnect the cable going to the LCD display.
Abschluss
Michael Martin
401 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S3-G5, Botvin Spring 2017 Mitglied von UMass Dartmouth, Team S3-G5, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G5
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 141
