Einleitung
If you find your waterproof case not as watertight as you had hoped, you might want to replace the O-ring. You will need a tool to pry the O-ring from the case.
Was du brauchst
To open the case, push the yellow "Open" tab located at the bottom of the case.
Pull out on the yellow tabs as indicated by the circles in the photo to unlock the lid. This may be a little tricky!
Then, remove the lid.
Take the plastic opening tool and wedge it between the O-ring and the groove.
Then, pry the O-ring until it is out of the groove.
Now that the O-ring is out of the groove, remove the O-ring from the lid.
