Zum Hauptinhalt wechseln
Sony Action Cam Mini HDR-AZ1 Battery Door Replacement
Was du brauchst
  1. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery: Schritt 1, Bild 1 von 3 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery: Schritt 1, Bild 2 von 3 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery: Schritt 1, Bild 3 von 3
    • To access the battery, first make sure the camera is out of the case.
    • Push down on the door lock, located on the rear of the action cam.
    • The door is unlocked if the little yellow square is showing.
    • Pull on the panel door, located on the side opposite the LCD screen, and it should now pop open.
  2. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: Schritt 2, Bild 1 von 3 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: Schritt 2, Bild 2 von 3 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: Schritt 2, Bild 3 von 3
    • Open the side panel outward to reveal the battery.
    • Be sure not to break the small piece of plastic securing the door to the camera.
    • Use the pull tab to pop the battery out of place.
  3. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery Door: Schritt 3, Bild 1 von 2 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery Door: Schritt 3, Bild 2 von 2
    • Remove the circled 4 millimeter black screw adjacent to where the door is attached.
  4. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: Schritt 4, Bild 1 von 2 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: Schritt 4, Bild 2 von 2
    • Grab the small black bracket holding the ribbon on which the door is attached and pull it out.
  5. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: Schritt 5, Bild 1 von 1
    • Pull the door straight back so the attaching ribbon is pulled taught and the door will come right off.
Abschluss
Mathieu LaFond
425 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 Mitglied von UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G7
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 711
