Einleitung
Is your battery door damaged or is the clasp broken?
Was du brauchst
To access the battery, first make sure the camera is out of the case.
Push down on the door lock, located on the rear of the action cam.
Pull on the panel door, located on the side opposite the LCD screen, and it should now pop open.
Open the side panel outward to reveal the battery.
Use the pull tab to pop the battery out of place.
Remove the circled 4 millimeter black screw adjacent to where the door is attached.
Grab the small black bracket holding the ribbon on which the door is attached and pull it out.
Pull the door straight back so the attaching ribbon is pulled taught and the door will come right off.
