Zum Hauptinhalt wechseln
Sony Action Cam Mini HDR-AZ1 Gasket Replacement
Was du brauchst
  1. Sony Action Cam Mini HDR-AZ1 Gasket Replacement, Gasket Seal: Schritt 1, Bild 1 von 2 Sony Action Cam Mini HDR-AZ1 Gasket Replacement, Gasket Seal: Schritt 1, Bild 2 von 2
    • To open the case, slide the tab located on the underside of the case to the “unlock” position.
    • Press in the tabs, that are on the sides of the unlock tab, and pull down. This should cause the lid to open.
    • Remove the lid.
  2. Sony Action Cam Mini HDR-AZ1 Gasket Replacement: Schritt 2, Bild 1 von 1
    • Using the plastic opening tool, wedge it between the O-Ring and the groove.
    • Move the tool around the ring, prying the gasket from the groove, until it is able to be grabbed.
  3. Sony Action Cam Mini HDR-AZ1 Gasket Replacement: Schritt 3, Bild 1 von 1
    • Remove the O-Ring from the lid of the case.
Abschluss
To place a new gasket in, follow these steps in reverse order, making sure the gasket is fully pushed back in around its entire perimeter.
Mathieu LaFond
425 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 Mitglied von UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G7
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 554
