Zum Hauptinhalt wechseln
Sony Alpha 5100 Front Plate Replacement
  1. Sony Alpha 5100 Front Plate Replacement, Battery: Schritt 1, Bild 1 von 2 Sony Alpha 5100 Front Plate Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide the power switch on the top of the camera to "off."
    • Turn the camera over to the bottom, and push the latch towards the side marked "open" to release the battery cover.
  2. Sony Alpha 5100 Front Plate Replacement: Schritt 2, Bild 1 von 1
    • Push the blue spring-loaded lever to release the battery.
    • Remove the battery from the camera.
  3. Sony Alpha 5100 Front Plate Replacement, Front Plate: Schritt 3, Bild 1 von 3 Sony Alpha 5100 Front Plate Replacement, Front Plate: Schritt 3, Bild 2 von 3 Sony Alpha 5100 Front Plate Replacement, Front Plate: Schritt 3, Bild 3 von 3
    • Remove one 2mm Phillips #00 screw from the flash plate cover.
    • Use the spudger to pop the plate off.
    • Remove two 2mm Phillips #00 screws on the side of the camera.
  4. Sony Alpha 5100 Front Plate Replacement: Schritt 4, Bild 1 von 2 Sony Alpha 5100 Front Plate Replacement: Schritt 4, Bild 2 von 2
    • Pop the memory card door open by gently lifting the door up.
    • Remove two 2mm Phillips #00 screws from the side of the camera.
    • Remove three 2mm Phillips #00 screws on the bottom of the camera.
  5. Sony Alpha 5100 Front Plate Replacement: Schritt 5, Bild 1 von 2 Sony Alpha 5100 Front Plate Replacement: Schritt 5, Bild 2 von 2
    • Use the opening tool to gently pop the front plate apart from the body.
Abschluss
Kevin Raggiani
444 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S4-G6, Saloman Fall 2019 Mitglied von UMass Dartmouth, Team S4-G6, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G6
3 Mitglieder
8 Anleitungen geschrieben
2 Kommentare
Hi, i need to access the shutter-on/off switch on my a5100. Which parts and screws do i need to take apart.?
Thank you,
Fabian,
Fabian - Antwort
Step 4 is missing one screw. Pop the flash and there is a screw there sideways that must come out.
Nick P - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 36
Insgesamt: 1,330
