Zum Hauptinhalt wechseln
Sony Alpha A350 Front Case Replacement
Was du brauchst
  1. Sony Alpha A350 Front Case Replacement, Front Case: Schritt 1, Bild 1 von 2 Sony Alpha A350 Front Case Replacement, Front Case: Schritt 1, Bild 2 von 2
    • Using a Phillips #00 Screwdriver, remove the four 5.5mm screws from the bottom of the camera.
    • Using a Phillips #00 Screwdriver, remove the one 4.3mm screw.
  2. Sony Alpha A350 Front Case Replacement: Schritt 2, Bild 1 von 2 Sony Alpha A350 Front Case Replacement: Schritt 2, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove one 3.6mm screw on the left side of the camera.
    • Open the remote / DC under the rubber flap to reveal a screw.
    • Using the Phillips #00 screwdriver, remove one 4.3mm screw.
  3. Sony Alpha A350 Front Case Replacement: Schritt 3, Bild 1 von 2 Sony Alpha A350 Front Case Replacement: Schritt 3, Bild 2 von 2
    • Open the flash on the top of the camera and remove two 4.3mm screws with a Phillips #00 screwdriver.
    • If the spring guard falls out during deconstruction, gently place the guard over the spring during construction.
    • To open the flash, simply press the button on the left side.
  4. Sony Alpha A350 Front Case Replacement: Schritt 4, Bild 1 von 2 Sony Alpha A350 Front Case Replacement: Schritt 4, Bild 2 von 2
    • Open the plastic SD card door.
    • Using Phillips #00 screwdriver, remove two 4.4 mm screws outside and two 4.4mm screws inside the door.
  5. Sony Alpha A350 Front Case Replacement: Schritt 5, Bild 1 von 2 Sony Alpha A350 Front Case Replacement: Schritt 5, Bild 2 von 2
    • Gently pull the outer front case from the camera.
    • It should fall apart easily if all screws are removed.
Abschluss
IUPUI, Team S1-G6, Henning Fall 2019 Mitglied von IUPUI, Team S1-G6, Henning Fall 2019
IUPUI-HENNING-F19S1G6
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 727
