Einleitung
If your power switch is damaged the best option may be to replace it.
Was du brauchst
Identify and unscrew the ten PH000 screws around the top, front, left, and right sides of the camera body.
Slowly separate the back case from the camera.
Idenify and unscrew the two PH000 screws connecting the power switch.
Remove the power switch.
Abschluss
