Was du brauchst
Press and hold the lens-release button
Twist lens counterclockwise, then out to remove.
Inside the camera at the top, there will be a small slit.
Insert tweezers onto the lip below the slit and gently pull it down.
Use tweezers to grasp the edge of the focus lens.
Lift the focus lens up and out of the tray.
Insert new focus lens onto the tray in the same position as the old lens taken out.
Insert tweezers into the slit and gently push upwards to lock the tray in place.
