Zum Hauptinhalt wechseln
Sony Alpha DSLR- A850 Viewfinder Window Replacement
Was du brauchst
  1. Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Cover: Schritt 1, Bild 1 von 1
    • Find the rubber viewfinder cover on the upper rear of the camera, above the view screen.
  2. Sony Alpha DSLR- A850 Viewfinder Window Replacement: Schritt 2, Bild 1 von 1
    • Slide the rubber piece off.
    • There may be a slight popping sound.
  3. Sony Alpha DSLR- A850 Viewfinder Window Replacement: Schritt 3, Bild 1 von 1
    • Once the rubber piece has been removed, inspect the area.
    • If everything looks fine, go ahead and slide the new rubber piece on the same way the old piece was slipped off.
  4. Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Window: Schritt 4, Bild 1 von 2 Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Window: Schritt 4, Bild 2 von 2
    • Remove all four screws from the viewfinder.
  5. Sony Alpha DSLR- A850 Viewfinder Window Replacement: Schritt 5, Bild 1 von 2 Sony Alpha DSLR- A850 Viewfinder Window Replacement: Schritt 5, Bild 2 von 2
    • Grasp the side of the window with either a set of tweezers or your fingers. Lift upwards and slightly towards the base of the camera.
  6. Sony Alpha DSLR- A850 Viewfinder Window Replacement: Schritt 6, Bild 1 von 1
    • To reinsert the window, push inward and slightly forward. There is a tab on the camera that the window must catch on in order to be put into place.
Abschluss
Richard Fabian
256 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 379
