Einleitung
If there is a problem mounting the lens onto your Sony Alpha ILCE-6000 , this guide will help you replace the E-mount ring.
Was du brauchst
Use the finger, press and hold the release black circle button ( on the bottom ) next to the lens on the front of the camera.
Using the left hand or the right hand to hold the camera body, other hand twist the lens counterclockwise and pull it off.
Take a Philips head 00 screw to remove the four of the 5.1mm screws located on the E-mount.
After removing the screws, pull off the E-mount metal ring gently and wiggle it until its free.
Remove the plastic ring located under the metal ring.
