Zum Hauptinhalt wechseln
Sony Alpha ILCE-6000 battery cover plate repair
Einführungsvideo
    • As they do not sell the plate alone, it is necessary to buy the complete door, I did it on eBay.com
  1. Sony Alpha ILCE-6000 battery cover plate repair, Remove the metal lid of the new door: Schritt 2, Bild 1 von 1
    • Since we received the spare part, we removed the plate from the new door, for this we put a very small flat screwdriver in the marked slot and pushed towards the side of the hinge.
    • We take the pin (safe) of the new door and place it in the original door in the chamber.
    • We put the metal plate on the original door and ready.
Abschluss
To reassemble your device, follow these instructions in reverse.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
es en
100%
Hier starten ›
3 Kommentare
Me funciono perfectamente!! gracias
javier.iracheta - Antwort
Very helpful. I was trying to figure out how to replace the entire cover but could not realize how to remove it since there's no easy way to access the metal pin. But moving the parts from the new to the old cover worked perfect! I needed quite a bit of force to remove the metal lid, but once done it was easy. Thanks for this tutorial!
Manav Shah - Antwort
Device disassembly cannot void your warranty in the US unless you actually break something in the process.
Christopher De Leon - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 47
Letzte 30 Tage: 144
Insgesamt: 4,355
