Zum Hauptinhalt wechseln
Sony Alpha NEX-5N Battery Replacement
  1. Sony Alpha NEX-5N Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before operating on this device, be sure the device is turned off.
    • Turn the device off by switching the power knob to face the word "OFF".
  2. Sony Alpha NEX-5N Battery Replacement: Schritt 2, Bild 1 von 2 Sony Alpha NEX-5N Battery Replacement: Schritt 2, Bild 2 von 2
    • Flip the device upside-down and gently place it down on a flat surface.
    • Locate the battery compartment, which is indicated by a grooved latch.
    • Push the latch to the right so that the arrow is positioned above the word "Open". The door should then flip upward.
  3. Sony Alpha NEX-5N Battery Replacement: Schritt 3, Bild 1 von 2 Sony Alpha NEX-5N Battery Replacement: Schritt 3, Bild 2 von 2
    • With the battery compartment latch open, locate the lock lever.
    • Press the lock lever to the left. This will eject the camera battery.
Abschluss
Demi Deletang
101 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 48
Insgesamt: 2,466
