Zum Hauptinhalt wechseln
Sony Alpha NEX-5N E-mount Replacement
Was du brauchst
  1. Sony Alpha NEX-5N E-mount Replacement, E-mount: Schritt 1, Bild 1 von 2 Sony Alpha NEX-5N E-mount Replacement, E-mount: Schritt 1, Bild 2 von 2
    • While completing this guide, do not touch the image sensor (the center rectangle encircled by the lens mount).
    • Unscrew the 4 silver 1.2 mm Phillips #000 screws along the front outer lens mount.
    • Applying extra force to unscrew these 4 screws may be necessary.
    • Detach the outer lens mount ring.
  2. Sony Alpha NEX-5N E-mount Replacement: Schritt 2, Bild 1 von 2 Sony Alpha NEX-5N E-mount Replacement: Schritt 2, Bild 2 von 2
    • Pay attention to the positioning and order of the spacing rings for reassembly.
    • Using your fingers, pull out the first black spacer ring.
    • Repeat the previous step for the second silver spacer ring.
  3. Sony Alpha NEX-5N E-mount Replacement: Schritt 3, Bild 1 von 3 Sony Alpha NEX-5N E-mount Replacement: Schritt 3, Bild 2 von 3 Sony Alpha NEX-5N E-mount Replacement: Schritt 3, Bild 3 von 3
    • Unscrew the 2 silver 1.2 mm Phillips #000 screws on opposing sides in the lens ring area.
    • Using your fingers, easily pull off lens housing. This will complete the removal of the E-mount.
    • The lens release button and the small spring underneath will be loose.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 1,301
