Zum Hauptinhalt wechseln
Sony Alpha NEX-5N Lens Release Button Replacement
Was du brauchst
  1. Sony Alpha NEX-5N Lens Release Button Replacement, E-mount: Schritt 1, Bild 1 von 2 Sony Alpha NEX-5N Lens Release Button Replacement, E-mount: Schritt 1, Bild 2 von 2
    • While completing this guide, do not touch the image sensor (the center rectangle encircled by the lens mount).
    • Unscrew the 4 silver 1.2 mm Phillips #000 screws along the front outer lens mount.
    • Applying extra force to unscrew these 4 screws may be necessary.
    • Detach the outer lens mount ring.
  2. Sony Alpha NEX-5N Lens Release Button Replacement: Schritt 2, Bild 1 von 2 Sony Alpha NEX-5N Lens Release Button Replacement: Schritt 2, Bild 2 von 2
    • Pay attention to the positioning and order of the spacing rings for reassembly.
    • Using your fingers, pull out the first black spacer ring.
    • Repeat the previous step for the second silver spacer ring.
  3. Sony Alpha NEX-5N Lens Release Button Replacement: Schritt 3, Bild 1 von 3 Sony Alpha NEX-5N Lens Release Button Replacement: Schritt 3, Bild 2 von 3 Sony Alpha NEX-5N Lens Release Button Replacement: Schritt 3, Bild 3 von 3
    • Unscrew the 2 silver 1.2 mm Phillips #000 screws on opposing sides in the lens ring area.
    • Using your fingers, easily pull off lens housing. This will complete the removal of the E-mount.
    • The lens release button and the small spring underneath will be loose.
  4. Sony Alpha NEX-5N Lens Release Button Replacement, Lens Release Button: Schritt 4, Bild 1 von 3 Sony Alpha NEX-5N Lens Release Button Replacement, Lens Release Button: Schritt 4, Bild 2 von 3 Sony Alpha NEX-5N Lens Release Button Replacement, Lens Release Button: Schritt 4, Bild 3 von 3
    • Find the lens release button.
    • The button should be easily removed by hand.
  5. Sony Alpha NEX-5N Lens Release Button Replacement: Schritt 5, Bild 1 von 1
    • After removing the button, the spring underneath it is uncovered and can be replaced.
    • This completes the removal of the lens release button.
Abschluss
Anna Tole
191 Reputation
1 Anleitung geschrieben
Ein Kommentar
What to do if the lens is attached to the camera and the release button is stuck?
on a Nikon d7100.
ajbakh - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 19
Insgesamt: 1,906
