Zum Hauptinhalt wechseln
Sony Alpha NEX-5N Motherboard Replacement
Was du brauchst
  1. Sony Alpha NEX-5N Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 Sony Alpha NEX-5N Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 Sony Alpha NEX-5N Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Unscrew the 3 silver 1.2 mm Phillips #000 screws from the bottom of the camera.
    • This does not include the two screws in the bottom of the LCD screen panel.
    Frag FixBot
    Kommentar hinzufügen
  2. Sony Alpha NEX-5N Motherboard Replacement: Schritt 2, Bild 1 von 1
    • On the bottom casing, locate the split along the tripod port.
    • Insert the prying tool into the split.
    • Pull the prying tool towards the LCD screen to begin separating the split.
    • Jiggling the prying tool may be necessary to open the split.
    Frag FixBot
  3. Sony Alpha NEX-5N Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Hold the device with the lens facing you, and grasp the battery compartment.
    • Locate the split on the side of the battery compartment.
    • Locate the split and insert the prying tool.
    Frag FixBot
  4. Sony Alpha NEX-5N Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Locate the charging port.
    • Unscrew the silver 3.5 mm Phillips #0 screw next to the port.
    Frag FixBot
  5. Sony Alpha NEX-5N Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Open the battery compartment.
    • Unscrew the 2 silver 3.5 mm Phillips #0 screws found at the inside bottom of the battery port.
    Frag FixBot
  6. Sony Alpha NEX-5N Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Insert prying tool in the split between the top panel (where you find the movie button) and the LCD screen.
    • Jiggle the prying tool and pull the tool away from the device.
    • The panel will fall off immediately.
    Frag FixBot
  7. Sony Alpha NEX-5N Motherboard Replacement: Schritt 7, Bild 1 von 2 Sony Alpha NEX-5N Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Unscrew the silver 3.5 mm Phillips #0 screw, visible on the left top edge when looking at the face of the device.
    • The dark gray panel that surrounds the shutter button and covers the battery compartment will be loose.
    Frag FixBot
  8. Sony Alpha NEX-5N Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Locate the middle top of the device.
    • Unscrew 2 copper 1.2 mm Phillips #000 screws.
    Frag FixBot
  9. Sony Alpha NEX-5N Motherboard Replacement: Schritt 9, Bild 1 von 1
    • To the right of where you unscrewed the copper screws, unscrew 4 black 1.2 mm Phillips #000 screws.
    Frag FixBot
  10. Sony Alpha NEX-5N Motherboard Replacement: Schritt 10, Bild 1 von 2 Sony Alpha NEX-5N Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Locate the tripod port.
    • Unscrew 2 black 1.2 mm Phillips #000 screws, one on each side of the tripod port.
    • Pull the section holding the LCD screen away from the device body.
    Frag FixBot
  11. Sony Alpha NEX-5N Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Unscrew 2 copper 1.2 mm Phillips #000 screws underneath the lanyard loop (near the control wheel).
    Frag FixBot
  12. Sony Alpha NEX-5N Motherboard Replacement: Schritt 12, Bild 1 von 3 Sony Alpha NEX-5N Motherboard Replacement: Schritt 12, Bild 2 von 3 Sony Alpha NEX-5N Motherboard Replacement: Schritt 12, Bild 3 von 3
    • Pull off the metal back from the device body.
    • Locate a thin metal piece on top of the motherboard, and unscrew 4 silver 1.2 mm Phillips #000 screws in the corners of the metal piece.
    • Underneath. you will locate the motherboard.
    • The tripod piece will be loose. Take the piece from the device and set it off to the side.
    Frag FixBot
  13. Sony Alpha NEX-5N Motherboard Replacement: Schritt 13, Bild 1 von 2 Sony Alpha NEX-5N Motherboard Replacement: Schritt 13, Bild 2 von 2
    • The top and bottom of the device has ZIF ribbon cable connectors holding the motherboard in place.
    • Flip up the white retaining tabs, and utilize tweezer to, pull out the 2 thin ribbon cables, located on top of the motherboard.
    • Do not touch the ribbons with bare hands.
    Frag FixBot
  14. Sony Alpha NEX-5N Motherboard Replacement: Schritt 14, Bild 1 von 3 Sony Alpha NEX-5N Motherboard Replacement: Schritt 14, Bild 2 von 3 Sony Alpha NEX-5N Motherboard Replacement: Schritt 14, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Locate 3 thick ribbon cables on the bottom, and flip up the white retaining tabs. Pull out the remaining ribbon cables, utilizing tweezers.
    Frag FixBot
  15. Sony Alpha NEX-5N Motherboard Replacement: Schritt 15, Bild 1 von 2 Sony Alpha NEX-5N Motherboard Replacement: Schritt 15, Bild 2 von 2
    • Lift the gray plastic camera piece surrounding the motherboard up.
    • Leave the long, thin ribbon cable that runs along the gray piece attached. It is not necessary to detach.
    • Lift up the motherboard to reveal one final thin ribbon cable connected to a white retaining tab underneath the motherboard.
    • Flip up the white retaining tab, and utilize tweezers to pull out the final thin ribbon cable.
    Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
2 Kommentare zur Anleitung
Thanks a lot friend.. My 5n don't star… some day the metal cortine closet after 1 minute I shot down the camera and never more star again..
I will try to fix it…
I live in Cuba and we no have technicians for this camera…
Best regard…
Ramon
ramon luis perez - Antwort Teilen
The flip up retaining tabs on the ZIF ribbon connectors are black rather than white as stated. Just want to point that out in case someone attempts to pry up the wrong ends and damages them.
Clive Woodhouse - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 24
Letzte 30 Tage: 100
Insgesamt: 6,866
