Was du brauchst
Turn the camera with the lens facing up.
Find the lens release button - located along the side of the silver lens mount.
Press and hold the lens release button while rotating the lens counterclockwise.
Lift the lens when it is no longer attached to the camera.
After removing the lens, you will come into contact with the lens mount. Start by unscrewing the four 3.5 mm Phillips #00 screws.
The outer lens mount ring can now be removed.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
For the first (black) spacer ring, use the tweezers to gently pry the ring out of place.
Repeat this step for the second (silver) spacer ring.
The third image is what the camera should look like after all spacer rings are removed.
To remove the inner lens mount ring, remove the two silver 2.0 mm Phillips #00 screws. This will complete the removal of the lens mount.
3 weitere Personen haben diese Anleitung absolviert.
