Zum Hauptinhalt wechseln
Sony Alpha NEX-6 Lens-release Button Replacement
Was du brauchst
  1. Sony Alpha NEX-6 Lens-release Button Replacement, Finding the Release Button: Schritt 1, Bild 1 von 1
    • Turn the camera with the lens facing up.
    • Find the lens release button - located along the side of the silver lens mount.
  2. Sony Alpha NEX-6 Lens-release Button Replacement, Removing the Lens: Schritt 2, Bild 1 von 2 Sony Alpha NEX-6 Lens-release Button Replacement, Removing the Lens: Schritt 2, Bild 2 von 2
    • Press and hold the lens release button while rotating the lens counterclockwise.
    • Lift the lens when it is no longer attached to the camera.
    • To replace the lens, align the white dot on the lens with the white dot located on the silver lens mount. (See image two)
    • Insert the lens and rotate it clockwise until it is locked in place.
  3. Sony Alpha NEX-6 Lens-release Button Replacement, Lens Mount: Schritt 3, Bild 1 von 1
    • While dealing with this guide, do not touch the delicate image sensor (the center rectangle encircled by the lens mount).
    • After removing the lens, you will come into contact with the lens mount. Start by unscrewing the four 3.5 mm Phillips #00 screws.
    • The outer lens mount ring can now be removed.
  4. Sony Alpha NEX-6 Lens-release Button Replacement: Schritt 4, Bild 1 von 3 Sony Alpha NEX-6 Lens-release Button Replacement: Schritt 4, Bild 2 von 3 Sony Alpha NEX-6 Lens-release Button Replacement: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Pay attention to the positioning of the spacer rings for reassembly.
    • For the first (black) spacer ring, use the tweezers to gently pry the ring out of place.
    • Repeat this step for the second (silver) spacer ring.
    • The third image is what the camera should look like after all spacer rings are removed.
  5. Sony Alpha NEX-6 Lens-release Button Replacement: Schritt 5, Bild 1 von 2 Sony Alpha NEX-6 Lens-release Button Replacement: Schritt 5, Bild 2 von 2
    • To remove the inner lens mount ring, remove the two silver 2.0 mm Phillips #00 screws. This will complete the removal of the lens mount.
  6. Sony Alpha NEX-6 Lens-release Button Replacement, Lens-release Button: Schritt 6, Bild 1 von 1
    • By using tweezers, carefully remove the lens-release button by lifting upward.
Abschluss
USF Tampa, Team 11-2, Blackwell Winter 2015 Mitglied von USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 21
Letzte 30 Tage: 63
Insgesamt: 1,771
